smart-rf-policy commands
The following table summarizes Smart RF policy configuration commands:
Table 1. Smart-RF-Policy Config Mode Commands
Command Description
area Configures the channel list and power for a specified area
assignable-power Specifies the power range during power assignment
avoidance-time Allows Smart RF-enabled radios to avoid Dynamic Frequency Selection (DFS) and/or adaptivity regulated channels on detection of interference or radar. This command configures the period for which the channel is avoided.
channel-list Assigns the channel list for the selected frequency
channel-width Selects the channel width for Smart RF configuration
coverage-hole-recovery Enables recovery from errors
enable Enables the Smart RF policy
group-by Configures grouping parameters
interference-recovery Enables recovery from excessive noise and interference related issues
neighbor-recovery Enables recovery from faulty neighbor radios related issues
select-shutdown Enables selection and shutting down of 2.4 GHz radios, causing interference, in case the co-channel interference (CCI) value exceeds a specified threshold
sensitivity Configures Smart RF sensitivity parameters
smart-ocs-monitoring Applies smart off-channel scanning (OCS) instead of dedicated detectors
smart-sensor Enables the Smart-sensor feature and configures associated parameters. Smart-sensor automates the provisioning of APs as sensors within a wireless deployment.
smart-sensor-status-timer Works in conjunction with the smart-sensor command to check the status of radio sensors. If the status of the sensors is Off, recalibration for the smart-sensor feature is triggered.
no (smart-rf-policy-config-mode-command) Negates a command or reverts settings to their default
For more information on common commands (clrscr, commit, help, revert, service, show, write, and exit), see Common Commands.
The input parameter <HOSTNAME>, wherever used in syntax across this chapter, cannot include an underscore (_) character. In other words, the name of a device cannot contain an underscore.
